Lay the oven vent and chimney over the opening at the front of the oven dome. This services as your vent, and the intersection to your chimney system. The front of the oven vent should be set flush with the front edge of the oven dome. Seal the oven vent and chimney manifold to the oven dome using a 1" layer of refractory mortar on the outside of the joints.
You are now ready to Attach the Arch.
Back to the Table of Contents.
Comments
